I have a few sets of springs from various mopar distributors. Do the lighter springs just have less windings?
FWIW,
More windings means less tension, larger spring diameter means less tension, larger wire diameter means more tension.
Great job explaining it Dave.
Dart66GT The Mr.Gasket kit may be ok but I'd be wary of generic stuff. I've had problems making some of that stuff fit right. Mopar perf. sells a kit made specifically for the Mopar distributors. Here it is on Mancini's site
http://chucker54.stores.yahoo.net/disadweigspr.html
Thanks for the advice dgc333. When you say one of the MP springs mated to the lighter of the 2 stock springs. Which MP springs are you referring to? And does that mean the light stock spring takes the position of the heavier stock spring, And the MP spring takes the place of the light stock spring?
Thanks again for all your help...
Thanks again. I'm ordering some stuff from summit and they have the 2 spring MP kit for $4.95. Just to make sure I have this clear in my head. When I get the kit. I leave the light factory spring right where it is and replace the heavier stock spring with the one from the kit. Is this correct?
I dont know why everyone is so uptight about springs. You can go to the hardware store and buy different springs and trial and error till you get the curve you like. ink pens have light springs and old electronics and turntables and such have them. You think the early drag racers had spring kits. They improvised.
Anyone know the part #'s for a Summit order??
