frederick_76
Before I fire up my 408 for the first time I want to set the dizzy a bit advanced from TDC, clockwise or counterclockwise for advancing?
If one knows which way round to put the plugwires on the dist.cap, one should already know the direction the rotor turns, which should help in figuring out how retarding or advancing is done.
If you left the dots at 6/12 o'clock: turn dampener slightly to 15 BTDC. clock the intergear/install dist with rotor toward the rear & slightly toward the drivers side (maintains OE plug wire routing letting em lay the neatest with the shortest lengths possible) & turn the housing slightly till the magnet is dead even with that tooth. plug in the #6 plug wire above the rotor & continue on around CW (6)-5-7-2-1-8-4-3. With the springs retracted (they should be) you want the rotor slightly to the trailing (CW) edge of the cap terminal since vac adv will shift rotor phasing CCW on a SB.Before I fire up my 408 for the first time
