CordobaDart
318 SLANTMAN
Very clean looking Barracuda there Dratsum, nice!
I know the feeling of helpless lack of power as well.
My limited experience with slant six modification is as follows:
PROBLEM: No power, floored all the time, must.. fix.
SUBJECT: 1983 W150 Power Ram Truck w/slant six and np435 4 speed. Single barrel carburetor with more silly attachments than a Kirby vacuum. Electronic Spark Control.
SOLUTION: LUCKY junk yard find Offy 4 barrel slant six intake for $50. Carter AFB #3853S bought off a stuck 273 v8 and rebuilt. 70's style Electronic Ignition setup. Plugs, wires, de-cat, de-air pump.
RESULTS: Huge improvement off idle and low rpm, no aparent signs of over carburation, no hesitation. Of course this is a 4500 lb truck, so it needs more fuel, but this small four barrel carb performs perfect and I have hauled bed loads of wood in 4 wheel drive as well without having to jam my foot into the floor constantly. Also note that this slant has the more wimpy hydraulic lifter camshaft, and still works great with the added fuel and air(though it stops pulling shortly past 4,000 rpm- good enough for this trucks use). Before this truck could only go 65mph, 70 downhill in 2 wheel drive. Now I am able to actually pass the 85mph mark on the speedo and have cruised happily at 60 in 4 wheel with ease. This engine is all stock other than the for-mentioned mods and a turbo muffler and downturn under the cab.
Anyhow, that's most of my limited slant six experience, good day, and good luck with yours!
