hi , i have a a2000 aeromotive pump after running it for 4 weeks ,its got real noisy its below fuel cell and rubber mounted line are -8 in / out an by pass ,has any one else had this happen an tips to fix it
When mine got noisy, and it sounded like it was vibrating itself to death,, well it did. about a week after the noise started it died. I used a holley blue for 3 years, but when you think of how many actual miles on it, maybe 300 it kinda sucks. I even have a filter before the pump. Put a second one in and 3 years later it's still going ok.
I think you're pump maybe on the way out. Can you get a rebuild kit?
If you are using it for a daily driver and your feeds are undersized you are taxing the pump....you can get a voltage limiter/controller for about 300 that will stop the problems you have but still able you to race and deliver gas when you need it.
Call
Aeromotivge...they are very coll guys that will bhelp you solve your probs.
They are about 20 miles from me and I am using their products as well.
Call them then tell us what they say....it will help us all.
After no more than 200 miles mine quit completely. took it apart - bottom sealed bearing had seized - replaced it for $12 and has ran at least 500 miles and 50 trips down the track. Their all noisey it seems.
Not to wave the flag but Aeromotive is made here in the USA....I don't know where Holly has there stuff made but I have a feeling some of it is not made here in the USA.
Call Aeromotive, the owner will do whatever it takes to get you going with his product. Lenexa, KS is the headquarters.
