65TerrorCuda
Changed jets, rods, springs, squirters, on a 1407 afb. Going rich on rods n jets did help but ended up with a cruise afr of 11:1. Not great.
Went back to standard jets and rods, then drilled the idle feed restriction tubes from a #63 to a #62 drill bit size and now it fries tires instead of chug-chug-chug when you wack it from a stop.
Super stoked and thought I'd share. It is a little rich on cruise, more like 13.5-13.6 but I can deal with that.
That afr gauge is a game changer
On another note,
I'm getting a super rich, 10.1:1 afr on decel. Floats are set normal height although I do have the larger float needles n seats. Any ideas on this? It's after a slight acceleration and gentle deceleration. Runs great otherwise. Fuel pressure is 3#, was at 5# and acted the same
On another note,
