Slantsix64
What size jets and rods, are you running? Can be as easy as a metering rod change, try a richer rod combo.
His issue doesn't involve the primaries.What size jets and rods, are you running? Can be as easy as a metering rod change, try a richer rod combo.
Maybe a secondary jet swap?His issue doesn't involve the primaries.
Man I don't know. Usually when there's a secondary tip in bog, the air door needs adjusting. Unfortunately, adjusting that one is a bit complicated. I'd sure try a jet change first, though.Maybe a secondary jet swap?
Accelerator pump volume?Is there a Quick Method to Tune the Transition when you Step-On-It?
Runs Great at Idle, Cruise and W-O-T...
but during Cruise it makes a BlehBleh before it Goes when you mash it.
Choke Fully Open and Warmed Up. I wouldn't mash it otherwise.
It's a Carter 500 on a 273 2bbl engine w/ a Halifax Distrib.
Runs Great other than this One thing...
What is it?
I say it may be a pump issue. The AFB is an older carb and maybe the plunger is old or hard and you are not getting the full 4cc. I need to change my plunger every couple years when I notice a difficult start. It is a easy try, without removing the carb and doing other adjustments. I would like to note, being your car runs fine, except for that miner glitch, right down all your starting points before any adjustments are made.I started working with Carter 4bbls in the 1970s. AFB, AVS & TQ. Also Edel later.
I have never used one or tuned one that needed more pump shot than using the outside hole on the pump arm, the least amount of pump shot. Later AFB & AVS,TQ & Edel used a 13/16" plunger. These are 4cc. Std Holley is 3cc, big pump is 5cc. So Carter pumps are quite big.
The problem with just up jetting the secondaries is it takes time to get the raw fuel moving through the boosters. I just remembered, you can pull the secondary boosters and see what the bottom of the emulsion tube looks like. Some are fully open ended and some are very closed off. View attachment 1716287092
Also, Edelbrock 1406 secondary venturi cluster
Nah, Runs Great! Pulls Hard all the way to 5k...
just sometimes has a lil stumble when your doing 30 behind some a-hole on the highway and you jump on it to pass.
I am not sure if the 500 cfm model has velocity valves [ weights ] in the secondaries. That looks like a factory carb.
What model is it?
Four digit # should be stamped on one of the mounting feet.
Does the carb have a large brass screw in between the idle mixture screws?
I can see one problem: it looks like it has a single plane intake.
Is the engine stock?
