1972orangebeast
- 3 - 11 - 1969 340 short block need rings, just had it running last year, but prob needed rings before that, has good steel 340 crank, has dampner, pistons, motor is std bore $900 -340 milodon 8 3/4 deep 8 qt oil pan like new has less than maybe 500 miles, no dents, has pickup and stock oil pump thats also like new just cant use it on my 360 or i would have $200 -360 stock factory oil pan from a car $50 -8 3/4 8.75 chunk 3:91 391 posi 741 casing $400 -340 adjustable rocker arms that cam on the 69 motor I have for sale, took them off and used regular stamped ones been kept covered in oil $150 -holley 650 dp double pumper spread bore factory carb, been sitting around in nice shape $100 -Griffin Universal radiator, i have brackets that i made for it not the prettiest thing but works, small electric fan on front good shape 27x3x19 $100 -Afco racing Polished Aluminum Radiator, will fit in dart if battery is in trunk or small mods to battery tray and no horns also, with stainless shroud and 17" electric fan, transmission cooler on front, looks greats fins are not damaged 30" from bracket to bracket rad is 26x3x19 $350 also some non Mopar parts too -I have Big Block Chevy Aluminum water pump $50 -Accel 300+ ferro-spiral ultra race wires with bb chevy hei cap $100 -Like New Powermaster starter used couple times, this was extra off of my backup motor Part Number 9426 250lbs ultra torque starter gm 153 168t $275 -Remote oil filter adapter, stainless braided #8 lines, and oil cooler $150 -New in Box Jegs 3 gallon fuel cell # 15301 $150 -Wilwood universal master cylinder and slave cylinder for brakes clutch $75 for both I am willing to ship anything and will make deals on multiple parts im located in central ohio send me pm for more pics or questions
Update I measured bore and is std , stock 69 pistons and rods
