abdywgn
dismantler
affordable, as in trade for complete Lakewood scattershield with block plate for big block...bolts, starter nose piece...no cutting, welding, parts that have been through an explosion. If in doubt, new is fine.
RWD, rear wheel drive, engine in front driving rear wheels as it should be
roller, no engine or transmission in 93 Dakota extended cab, 2WD, 3.92 8-1/4" open, 2.5" magnum exhaust manifolds into 3" head pipe, gray interior, blue with silver inset on sides, peeling of course. Under rail bedliner and fiberglass cap. If you would like the 5.2 and the A518, we can work something out...say a 440 Performer RPM intake.Intake should be like out of the box, no porting or cracks or just a little thing that needs to be welded. New would work wonders here also. PM for pics if you are able to come pick the vehicle up. Thanks! Bob
