Mine gets changed in the spring asap, It drives from the garage to the barn or to the local shop and i change it. I do an actual lube, oil, filter. Grease the chassis components, steering, drive shaft, then 7 quarts of 5-40 rotella t-6 and a fresh mopar filter.
I know when i parked my car there was no water in the oil. When i go out there in spring, i can pop a cover off and you can see all the condensation. Everytime the garage door goes up there goes the heat, now its 40 degrees in there, right about dew point.
