dano
Evil Handy Man
I talked to them. Stock tank with efi pump. $800! Not!
$235 is what they told me for just a tank shown below. Here is their exact quotes:
"$235.00 for the tank only, pump, sender and fittings are sold separately depending on what you need, all of that is listed on our website."
"If you are going to use this tank, you would use the GPA pump, which one depends on your EFI system or engine, in your case (I asked about MSD Atomin or EZ-EFI) you would want the GPA-4 pump. There are two holes on the top of the tank as you can see, one is for the pump the other one is for the sending unit, so the stock one won’t work, but an aftermarket one will."
I agree, no gas tank is worth $800.....
