replicaracer43
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,051
- Reaction score
- 7,867
I have some W2 stuff, with the offset shafts and blocks, but it definitely ain't moved that far...
Thank you SirThat is the company. Redding CA. They will do a nice job on your rocker arms.
How much more for that ??Yep. Just had a set done up by Gary. Very nice man. They came out great. Only thing I didn’t do was have the ratios all corrected. We talked about what I was doing, they’d be fine for street/mild strip. It’s not a max effort race engine so he agreed the added expense wasn’t worth it.
$170 plus per shaft alsoThose shafts are pretty thick and I'd bet with properly dimensioned blocks, there is no flex or movement. That gap will be supported.
Cant say that I've ever seen a rocker shaft machined almost in half before....interesting
My understanding is that the blocks on race heads are offset to center the wipe from the rockers. Much like the shim kit that B3 makes, the blocks are adjusted to position the shaft on the Race W2. Econo heads would need the shims in the saddles and the holes still have to be bored off center in the shaft to accommodate the bolts.
Well here’s the thing...it’s expensive. I had to buy a complete set of 273 adjustable rockers as I had nothing to start with. I was looking for a long time for a nice set, I found a very nice set from a member here. I paid $235 shipped to my door for them.How much more for that ??
I just have to weigh out modifying these nos Mopar rockers versus new Harland Sharp etc ??
View attachment 1715738015 View attachment 1715738016 View attachment 1715738017 View attachment 1715738018 View attachment 1715738019 View attachment 1715738020 View attachment 1715738021 View attachment 1715738022 View attachment 1715738023
Sending them off to RAU, he shot peened them, hard chromed the shafts, bushed the rockers, spot faced them and installed new adjusters with lock nuts, and resurfaced the rocker pads and he threw in a set of billet steel hold downs. That service was $508 with return shipping.
I didn’t see a need to spend any more to have all the ratios corrected for what I was doing, as I was already at $700. :0
my thoughts were, I never had these rockers before, always wanted them. They’re US made, and I supported a gentleman and his business, money stayed local. I was happy to pay it.
They are going in a mud truck with a solid cammed 360. Not a race car.
.620 less the lash. KimThank you - wonder how much Mopar unbushed W2 econos could take ?
