superdart
Shade Tree Tinker Gnome.....
Background:
My car is currently a column shift automatic. I have a factory center console/floor shifter, and a floor shift steering column to go in it.
My recently discovered issue is that my 518 will not work with factory A-body floor shifter. Since it was never used in a floor shift vehicle, it is not cast with necessary mount points for the floor shift linkage.
It now appears that I need to go with an aftermarket cable shifter.My questions are:
Who has good/bad input regarding specific shifters?
I would like to still use the factory console, and install the cable shifter in it. Does anyone know of a good way to pull this off??
