Gotta set the intake down 1st then install the valve covers.I have some aluminum Mopar valve covers and a Weiand aluminum intake. This combination is not playing well together. Any tips on how to bring them together?
Thanks
I had to use these for valve train clearance on my TF's. I also had to do some grinding on the inside of the spacers for clearance for my pushrods. The machining and fitment was first class.Medice Mfg. makes valve cover spacers if you decide to go that route:
MediceMfg ...Valve Cover Spacers - Mopar
Felpro VS50184R Valve cover gaskets are what I use. They are a little bit thicker than cork. 0.190 ThicknessYes that is the exact intake I am using, but for some reason the Mopar Performance valve covers will not sit correctly.
The spacers are too expensive, it would be a tralmost $100 for the Felpro gaskets. I'm having no luck finding the SCE gaskets. I have a spare Felpro gasket to double up with a used one from my stock valve cover and see how that works.
They were some tough valve covers...I think small block chevy are similar. you have t pull valve covers on them tooI was pulling an intake once, couldn't get it to turn loose. Bopped it with a mallet, pried with a big old bar, nothing. I ended up with a cherry picker hooked to it and the suspension unweighted before I realized the valve covers were holding it on.
