[WANTED] Aftermarket wheels, 17" (maybe 18) BBP
Jarlaxle
New England
Because nobody makes 15" performance tires anymore, I am upgrading to 17s-looking for a set of 17x7, going on a Duster. I'm not really sure what style I want, I'm open to almost anything.
I'm in New England...the closer the better, but I am willing to pay shipping or drive somewhere to get the right wheels.
If they have good tires, that's even better.
If you’re on a budget Mustang wheels. If you really just want anything in a 17” look at Cragar Soft 8’s. Around $90 a wheel I believe. Big weight penalty though. They have mopar friendly backspacing, at least on my 70 cuda. Now I’m running an 18/19 combo.
Yokohama makes really good $$$ friendly tires in 17.
@Jarlaxle
I agree.
Been a bunch of years but I bought some 17x8 wheels for a '97 GT and spent $90 in total for all 4. They don't match (different color in the spokes) but most people don't notice. You would have to open up the center a little and might have to run a 1/4" spacer and longer wheel studs but other than that they should bolt on.
Get some decent 245/45R17's and you should be good.
Sorry I can't help with an actual set of wheels but I would watch CL and MP for a set of wheels of a '95-04 Mustang GT. Look for a 17x8 +30 wheel.
Oh, you might need a wider rear axle too. Forgot about that.
He might have an 8.25 rear being a 73 and those are even more narrow. At the very least a spring relocation may be required.
Yeah, the axle is a trouble spot. I run an F-Body 8.25" because it is about the same width as a '65-67 B-Body and it work well. But a stock A-Body axle of any size might have a problem with the +30 wheels.
I was kind of focused on the front setup and forgot about the rear axle until the end. But he isn't going to find a 17" Mustang wheel with less offset that I am aware of. And anything that has less offset isn't going to work as well in the front with a 245 tire.
