Newbomb Turk
Most of the time I am right at 9 lbs of boost when I get on it.
Jack
How much timing are you pulling per pound of boost?
Jack
I don't pull any timing. I have my timing locked at 31 degrees. It seems to work well for this engine. Remember it has been together for 11 years and about 1500 miles per year. And I drive it, not baby it, just ask the wife. lolHow much timing are you pulling per pound of boost?
Jack
Jack, keep in mind those engine calculators and real life are often not the same. I already know you know that though. Yes, I agree. I think you came out of this pretty good IF you had to have a failure.I just came back in from taking the drivers side head off. It was pretty much the same story as the passenger side, just not as bad. It looks like I am going to get out of this with just some gaskets.
I did check into what my pressures should be and it looks like with an 8.2 to 1 engine like I have my cylinder pressure should be about 155 psi. So the 168 was not that far out of line.
Here are a couple of photos of the drivers side.
Jack
I would probably do exactly the same thing.After lots of thought I have decided what I am going to do. I decide to go with the Fel Pro 1008 gaskets again. Reasons for this. I can get them locally, they lasted 11 years the first time, I do not have to remove the engine to have it resurfaced. That's a big one. Don't have to have the heads resurfaced. Less chance of water leaks. Cost, although not a big factor, does come into it a bit. I am going to install them with a 3 step torque sequence, then let them sit overnight and retorque them in the morning. I will then reassemble the rest of the engine. I will run the engine through 3 heat cycles and then retorque the heads again. After this I will retorque the heads once each winter.
I know some will not like this idea but it is what I am going to do. It is a quick and cost effective way to address the problem. Getting work done on an engine around here is sketchy at best. Wait times can be up to 6 months and I am not going to wait that long to get the decks and heads resurfaced.
Jack
One of those things you hear a lot from people who haven't tried it themselves... I asked my machinist (experienced race engine builder) if I needed to deck my 5.9 Magnum block to work with Cometics. He said not to worry about it, factory finish is fine. Engine has been together with ARP studs for 7 years and at least 10k miles, zero leaks. I don't think Cometics are really necessary though considering OP has iron heads and boost level is pretty moderate.I think people worry about the surface finish requirements too much. Especially on a deck surface that is not freshly machined.
None of the plugs were damaged. One was fouled a little. I run my fuel mixture a little on the rich side to start with and that is what 7 of the plugs showed. It was just #6 that was fouled and that was the one that the gasket showed as the worst.Remember that detonation can create enormous cyl pressure.
Maybe it's not the gskts or o-rings.
Just curious if that plug was damaged by mishandling, or other .
Good luck .
I started my 340 up this spring and noticed a **** load of blow by. I finally got around to doing some tests on it today. Compression is all over the map. There is light blue smoke coming out of the tail pipes. And you can see the amount of blow by in the video. The plug check showed all cylinders a little rich except #6 which showed a little oil fouling. The car still pulls like a freight train. Keep in mind this is 340 with a roots 6-71 blower on top. I am pretty sure a complete refresh is in order. Rings, bearings and a hone job for sure.
Compression test results:
1------128
2------121
3------120
4------118
5------122
6------95
7------112
8------168
What do you think?
The retorquing is something I was thinking of doing not what I have done in the past. A straight edge goes on it tomorrow, I didn't get a chance to look at it today. Life got in the way.Since this engine was together for so long with zero issues is there anyway you fired it up this year on old pump gas. I just wondering if it got stale on you. As far as retorquing head bolts as often as you do you are stretching your bolts year after year if you aren’t replacing them. Good luck. Ohhhh I would put a machinist straightedge on those areas you pushed the head gaskets at a bare minimum.
I did put 5 gallons of fresh gas in before I started it in April. I did start it a couple of times during the winter though.
Jack
Twice for me, once cold and once after a heat cycle.I torque mine twice on the engine stand and never again.
I started out at 28 degrees. I slowly upped 1 degree at a time to the 31 degrees. I even drove it trying to get a ping out of it and never did. The engine just seems happiest at 31 degrees. I even upped the boost to 12 lbs once and got on it for a couple of short bursts. The only thing that did was break a balancer and timing cover. Sure was fun on those 2 bursts though. lol That was a few years ago now and maybe that was the start of the gaskets migrating. Who knows? I know I don't.https://www.scegaskets.com/wp-content/uploads/2023/11/ICS-TITAN-INSTALLATION-INSTRUCTIONS.pdf
Integral O-Ringed Copper Head Gaskets
https://www.scegaskets.com/wp-conte...ER-HEAD-GASKETS-INSTALLATION-INSTRUCTIONS.pdf
For the ultimate seal and protection from head lift or aggressive total timing applications, O-Ring the heads and cut Receiver Grooves in the block.
With that said, 31* of Total Timing is a lot for 9PSI of Roots boost.
Jack
