72Dart360
I put together a 904 with transbrake. The front drum has a bleed off hole drilled in it. The issue I have is when air checking the front clutch air is coming out the pump. I can hear the piston move but im not sure about the air leakage. This is my 1st build with a drum that has a hole drilled in it so I'm not sure if this normal or not.
