Small block bellhousing has a chip on one corner and the bottom thread do not look good ....might need heli coil ....im not sure which holes are needed and which ones are for 3 speed. $40. plus ship.
1970 2 barrel air cleaner. lid is a little rough and the previous used a hole saw to make 6 holes. $0.00 plus ship.
440 air cleaner most of the paint is stripped off and the metal on body is very solid, not dented up or rust crusted. the lid had crinkle coat at one time and looks worse than it is, has a dent on the edge but no rust crust, definitely needs re-finish. $60 plus ship
all ship from Colorado
