I recently purchased a 60 gallon air compressor and will be installing it in my garage. I plan to use it to restore my dart. Therefore, it will be running all of the normal air tools such as DA sander, air chisel, impact wrench etc.
But I also plan to use it to paint the car.
I'm new to setting up this thing and would like suggestions as to how I should configure the system.
From what I've read, I know I'll need a dryer for the line to keep moisture out of the paint. But other than that, I'd like anyone's expertise offered.
For instance, I'd like to know the specifics such as where specifically should I place the dryer....and or filter?
Should the dryer be close to the compressor or closer to the end of the air line?
Is there anything else I need to install in order to make the system work for what my intentions are?
I simply want to install this thing the right way the first time.
Thanks guys
Thanks guys
