air conditioning....yes or no?
'66Dart
Active Member
Torrance, Ca
My dart has an a/c unit and was told that it has already beed converted to R134a, just needs to be charged, no clue if thats true. Should I pursue getting it working or is there any upside to ripping it out, bolted on a /6 225.
If it's R12, it "should" still have the original flare service ports. If it's been converted, it "should" have the new style R-134 ports added "on top of" the original ports.
Are you sure it's leaked, or something else wrong? Scare up a set of gauges, and see if there's pressure in the system. Unfortunately, ambient saturated pressure/ temp for both refrigerants are so close, you probably cannot tell from that.
An example of R134 conversion fittings:
I will check fittings tomorrow, went out to start the daily driver today and it wont start, new project now, will let you know. Thanks
Local shop charged me $40 to pull a vacuum on mine and add r134.
The car had been previously converted, but was blowing hot and hadn't been driven for months.
I took a chance, and it started cooling as soon as it had enough juice.
It's been blowing cold for about 3 months, but is starting to be less cold.
I'm glad I did it, as it got me through the summer, and now I know the system is in relatively goos shape.
Nothing like curising around in a 38 year old car with working a/c!!
Now to find the slow leak...
Your in Ca. I would do it..Like YY1 said most independent shops charge around $40 well worth it ..The shop I used put in a Redish colored product just case it did leak we could see where the leaking problem was and that was at N/C.....
Go to autozone; they lend/rent you the vac pump, gaudes for free. to convert, you just change 2 fittings. Then charge with 134, takes 2 hours for all of it. $40 at most.
I draw a vaccum by connecting to manifold pressure to get most out, isolate w/ valve, then use a Mighty-Mite hand pump to get way down. Takes ~2 min of pumping. I let it sit 30 min and re-pump. Pressure goes up slightly due to outgassing and water evaporating, which is the main reason to pull a vaccum.
If you don't know what it had, and hate dealing with shops like me, you can add an HC refrigerant. Many brands, I have used Duracool. It mixes with R-134A or freon and all oils, and works even better than freon. Some will scream "flammable", but R-134A is flammable and poisonous, plus being outlawed by EPA. Soon new cars may use HC.
I would keep the a/c but your /6 will be struggling to pull out into traffic with the a/c on sucking more power.Either slant six is weak in power...170 - 101hp & 198 - 145hp I would defintely do some power upgrades but be mindful that you may have to upgrade the cooling system if you go overboard. There a lot of /6 guys here that can help you out. Also checkout slantsix.com
All true. A throttle position switch to cut power to the A/C compressor at wide open throttle would stop that power sucking. And I understand the Sanden - type compressors turn a lot easier, less power drag all the time.
ATB
BC
Those are the ones, starting to cool down here so maybe ill look into charging it next year, thanks guys
