Edelbrock copied the stock intake(s). View attachment 1715124749
That's an Edelbrock intake. lol
in the pic, there is not a 1/2" pipe fitting in the 1/4" hole,Ive already posted the picture of that twice here; do I need to post it a third time?
look at ur own pic, there is a 1/4" temp sender in the 1/4" hole !Ive already posted the picture of that twice here; do I need to post it a third time?
It`s apparent that a couple of u guys don`t know pipe sizes at all. The last pic has the treaded portion of the fitting, the same size as the hose side. No way 1/4" pipe is the same diameter of a 1/2" hose or fitting ! Done w/ this ----------------1/4" pipe thread, 1/2" hose size.
GRAINGER APPROVED Hose Barb,1/2 In Barb,1/4 In MNPT,Brass - 6AFH9|6AFH9 - Grainger
photo shop.....in the pic, there is not a 1/2" pipe fitting in the 1/4" hole,
Here's a 5/8" barb- 1/4" pipe thread which is just over a half inch in diameter.Somethings wrong , no way a 1/2" pipe nipple will fit a 1/4" pipe hole !
Oh boy, do I look like an idiot now! I guess it's been a long time since I saw a stock 340 intake manifold! Sorry bout that guys.That's an Edelbrock intake. lol
I've never liked the way they size these things, but for those who don't know, here's the reason for the confusion... the numbers don't really match the size although it's close on the inside diameter.
photo shop.....![]()
^^^^^^^^^^^^If I had Photoshop maybe I could have put a pair of tits on it. Everyone likes tits!
LOL, agree w/ that. What most people don`t realize is, that pipe sizes "are" the inside diameter of said fitting or pipe. I don`t think I`d run a 1/4" m.i.p. x 1/2" hose barb fitting on anything tho!
That'll work great. One thing, however: I do not like using brass. Sometimes due the softness of the material, brass cracks due to vibration. That fitting is susceptible to a lot of engine movement, and vibration. I'd use steel for better strength, or better yet stainless steel for the anti-corrosion factor too. (Note that the OEM fittings at the engine were steel).Here's my 1/4" mip x 1/2" hose... you don't this this will work?
Well, brass frost plugs are fine. They are not being pushed/pulled by a hose connected on one end to the body and one end connected to the engine. But, since you have the brass fittings already, use them. Obviously, they are not really "wrong". It just isn't what I would have bought for the application.I somewhat agree with that but I'm going to use the factory hose holder behind the alternator to keep everything still. Brass will last forever... I have brass frost plugs too.
The factory used steel because it's cheaper.
Oh, that isn't my engine! I found the picture via Google. Thought it was a stock engine! Guess not. Looks fantastic, anyways.Sure but the other end of the hose is attached to a heater core... not exactly bullet proof strength there with that paper thin beauty. With the hose holders in place nothing really moves. You're right pointing out that you don't want the hoses moving around too much.
I'm going to set mine up like you have yours. That's ideal... nice tidy engine compartment too... looks great.
What pulleys are you using there? I need some like that.
Is that a brass fitting on your fuel inlet?kidding!
I used to have a 69 GTS... worst (auto related) mistake I ever made selling that car
I`ve used brass fittings for over 40 yrs. in plmbing, and on 4 diff hotrods, have never had any trouble w/ them breaking from vibration or rot,much unlike the steel ones that rot and rust out. Two 10 sec. cars , one 11sec. pick up, and now an approx. 723 horse stroker motor------all brass !Have a look at CVF Racing for those pulleys.
looks like 3/8 x 1/2" to me , hard to tell in the pics tho.Here's my 1/4" mip x 1/2" hose... you don't think this will work? The hole through the center only has a small step in it (like 0.1).
