Not directed towards you at all, I seen the thread and I run air shocks on my 66 Valiant sedan, and keep 55 lbs in them, when I pump them up to 100
it stands way up I am looking forward to getting new springs on :cheers:
The springs will help body roll (being farther out/wider location) and the air shocks are WAY inboard and don't help much for body roll.
I will be going stock 66 v8 Barracuda springs to keep it close to a good level ride and add a front sway bar. I did not mean to make it look like I was telling you what to do, it's a must do for me :cheers:
for example :glasses7: before and after air shocks on my old 47 year old springs
A lot of people use them,to band aid worn leaf springs.
Mike...Re: the body roll...you can help this by installing 2 independent air valves...one for each side/air line...that way the air doesn't migrate side-to-side during cornering.
Really, air shocks (or SS springs) aren't designed to control body roll...sway bars are.
Sorry mike I must of read it wrong. Since someone laughed at what you said I thought u were making a joke. (As if I was too lazy to replace springs and instead installed air shocks as a quick fix.) my bad. Lol
On another note how much air pressure is supposto be in the shocks. And also if I install my SS springs, how do guys stop the rear end from sitting up so high Sorry if these are stupid questions
bullshit. if you are trying use them on a rusted out hulk with three deer carcasses in the trunk playing dukes of hazzard then yes.Another 'benefit' to air shocks is that the mounting stud up top isn't made for that type of stress load, so it can easily crack/pull-out/rip apart that brace. .
Another 'benefit' to air shocks is that the mounting stud up top isn't made for that type of stress load, so it can easily crack/pull-out/rip apart that brace. Air shocks were before my time, but a friend with a frame/alignment shop showed me on my old '68 GT (which didn't have them) why you should never put them in.
Have a set of Gabriel Hi-Jackers on mine. Just run enough air in them, to keep the car leveled out. Mine rides just fine. Sure, run too much air, and they will ride rough.
Oh Mann,.. I can't believe I haven't seen this thread before..
Back in the day, air shocks were the perfect answer to a week-end warrior at the strip..
Air shock with dual inlets allowed you to pre-load the rear end.
you'd put about 15 - 20 lbs more air in the right shock (like super stock springs)(adjust tire pressures to get and even patch of rubber off both tires ( too low -burns the outsides, too hard, they show more center) .. adjust the pinion snubber,, you got it all..
then lower the pressure for street use, ( if nec,.)
Thanks "is best" I've seen guys do that already I will for sure do the same. How far apart did you drill your holes from one another
