Air Shocks
Kegan B
IN
Who else is running them and at what PSI?
They were on my car when I got it and i ran them for a bit at 40lbs. IF you run air shocks they need their own supply line to each shock and you want to keep the air at a minimum so they can actually work.
With that said, mine went in the trash in short order.
Yeah mine are routed right and stiff at 90psi but backed down to 55psi the other day. Mine are only a couple months old and I'll probably still run them even after I have S/S springs on.
If you run SS springs I would get a quality shock too. You need to check the springs compressed and hanging and buy shocks accordingly so you get full function from the springs.
I have a set and love them! keep them at about 85 psi and they'll react when you put it to the floor at a standstill. If you play around with the psi with launches, you can tune them a bit. My dad did the same thing with his 454 chevelle back in the day.
