I'd say 9 times out of 10 most would be better off grabbing a running 5.9L magnum since it makes 300-320 hp in stock condition add small cam 360 hp easily and decent powerband 1000-5000 rpm. Second choice a 5.2L magnum same heads just a 4bbl cam headers away from making 400 hp, LS guys love 4.8L/5.3L they can make slightly more hp but the Magnum is what we got nothing stopping the chev guys from running small cid.
Secondly is getting traction in the street if your just building a tire burning throttle blip rocket than ya you want the most cid for low rpm torque.
But say you want a balanced driving experience, say got early 4 gear A body make it handle a little a want to rev through the gears and hook up well from a stop and not have crazy power so you can enjoy at street speed 0-80 mph so like 300-325 hp well a 5.9l magnum it makes that hp stock but it peaks at 4500 rpm cause its a truck engine.
Makes for a good daily driver and fun car but not a hot street machine that you can rev through the gears a 273/318 would fit the bill more on that one. Sure you could build a high revving 360 or 572 for that matter but hp gonna be so high your gonna have to drive 100 plus mph to enjoy or short blips of the gas that will melt tires at will.
I feel i need to change my username....
318istrashTo what? Hardly.
To what? 318saPOS? Hardly.
318istrash
ant red x'in ya but i havta disagree!318istrash
273, another great engine
Unless you already have a 67-69 or 85-91 9.2:1 motor.
How come no one ever mentions that?
A 340 cam,LD4B and 650 AVS2 (also on the shelf) , 340 exhaust manifolds, a higher stall converter, and 3.55's. Naw. I might just keep the stock 318 2 barrel.1968-9 9.2
1970 8.8
1971-3 8.6
is what I found.
My 70 has 8.8. I should switch to the closed chamber 920's I have on the shelf. That would get back to that 9.2.
Or I have a roller teen block in the garage. Oh and a pair of Speedmaster aluminum heads on the shelf and a 273 forged crank. I should build the aluminum head roller, dyno it, and sell it to someone in need. Should be able to squeeze 375-400 horse out of one without too much work.It is a slippery path.
I've said it before. I used the mopar
P4452761 in a low compression 318 and it worked great.
I used that exact cam in a LA 360 once, years ago
I saw it posted on a You tube video and thought I would screen shot the specs. Always lots of questions about purple shaft specs here.I used that exact cam in a LA 360 once, years ago
That 360 ran 13.3's with that cam, and 3.23 gears (28" tires). 2.02 J heads, LD 340 intake and 750 DP.I saw it posted on a You tube video and thought I would screen shot the specs. Always lots of questions about purple shaft specs here.
