Need recommendation for alignment for 69 Barracuda in San Antonio/Hill Country area.
Tried two in Boerne with no results.
Thanks
So the First Friday night of each month is "Mopar Night" at Biff Buzzby's (Toeperwein & 35), check with the gang there. Paul, Josh or Syliva would be your best bets to ask. Find the line of older Mopars, you'll probably find them. Also, the Mopar Muscle Club -San Antonio is having a show/swap at the same location on 11/18. You'll have a larger base of folks to ask then.Need recommendation for alignment for 69 Barracuda in San Antonio/Hill Country area.
Thanks
Thank you! I'm there!So the First Friday night of each month is "Mopar Night" at Biff Buzzby's (Toeperwein & 35), check with the gang there. Paul, Josh or Syliva would be your best bets to ask. Find the line of older Mopars, you'll probably find them. Also, the Mopar Muscle Club -San Antonio is having a show/swap at the same location on 11/18. You'll have a larger base of folks to ask then.
Looking forward to seeing that fish out there some time.Thank you! I'm there!
I know I'm late to this post, but I use Performance Off Road. They are just outside of Boerne on Highway 46. Elijah does the alignments and he is very good at it.Need recommendation for alignment for 69 Barracuda in San Antonio/Hill Country area.
Thanks
thanks i will check them outI know I'm late to this post, but I use Performance Off Road. They are just outside of Boerne on Highway 46. Elijah does the alignments and he is very good at it.
What time?Thank you! I'm there!
Is there a time to be there? Thinking I might drop by in March, missed Feb already.So the First Friday night of each month is "Mopar Night" at Biff Buzzby's (Toeperwein & 35), check with the gang there. Paul, Josh or Syliva would be your best bets to ask. Find the line of older Mopars, you'll probably find them. Also, the Mopar Muscle Club -San Antonio is having a show/swap at the same location on 11/18. You'll have a larger base of folks to ask then.
