O K! I did get the square back in, no problem except it hit the head/ valve cover which I barely got the fan belt on, but did. seems was set up for the single field wire. ordering the earlier style alternation doesn't necessarily work, as they will sometimes send the square back one anyway.
I stated a thread last week on "start issue". it all started when I switched out my 65 dart battery to start the tractor, returned it back to dart, went brain dead, and for a split second put battery wires on *** backwards, for a split second. I go to start the dart, it would start but only keep running if I help the key over to the start pos. (ign?).
I then switched to a NEW ballast and it would start/run normal/ I see some smoke coming off the NEW ballast, maybe just normal from being brand new!???? the VR I had on there was a new one I had put on there while back. I have only yard drove this car, needs exh, no reverse, etc!
so then I bigin tp esearch all the electrical problems/fixes on here. get out my dandy " free" HF meter, which I hardly know squat about and try getting V reading here and there!!!!!
SOoooooo....... one question: I can put the meter (set at where it says 10A) on the battery, ( no cables hooked to it), it will read like 13.5 and steadily keep going down in numbers, quickly....... does same thing when car is running, will say like 13.5,split second late 13, then like 12.7 etc......
I the coil + was reading like 3.8, which I understand is low. the fished it out, was new, and put another new one on there I had, same reading
when running the amp gauge reads very slightly to the discharge side of center.
do I have the meter se right. ??? can't find instructions! LOL
or as I have studied on here, a fall in current somewhere?????
