j par
Well-hung Member
can I take my alternator belt off for the quarter mile?
ccasion:ccasion: Or will it affect my ignition?
What will run your water pump?
Are you "throwing" it, or just looking for et/speed? Unless you're looking to get to some milestone" number, I'd leave it on and forget about it.
Congrats! Nice work. If you get deep enough in the 14.0x range, I wouldn't be opposed to pulling the belt.....might get you a couple "hun". Don't forget to get your front tire pressure up also...but for the track only. Not sure of your front setup, but 40/45lbs is not out of the question on the drag strip. Will probably give you just as much as the missing belt...
IF you isolate your voltage regulator from the ground,(so it won't charge) and make a small bracket and switch, on the throttle. With a wire from the voltage regulator to the switch on the carburetor. Adj the switch to go open at full throttle.
Now you have a charging alternator that free spins going down the 1/4 mile.
- Low voltage (<12v) will cause less spark-energy which can cause slower ET.
- Evenso, are you running the coil with or without a ballast resistor? Without one will let the coil make more spark-energy, but it will heat up a bit more aswell. Mount it in a cool place.
- That plastic fan is pretty useless imo.
Any more enginebay pics?
I just put a little electric motor for the water pump and fan.
I Drive to the track, and hopefully back! :burnout:View attachment 1714743529
- Always run the highest psi in the rear tires which still provide grip.
- One or two revolutions of tire slip from the start can even help improve times when you don't have much torque @ low rpms in the engine.
- With how much rpm do you cross the line?
- Did you time and curve the ignition properly?
Just a heads up. My friend and I installed the Moroso electric water pump drives on our cars at approximately the same time (like what you have in the picture). The only difference was he put a plastic fan on the water pump drive and I used my electric fan...he has now killed 2 of those electric water pump motors and I'm still on my original. I would be willing to be those things don't like the extra drag of the fan on that little electric motor. My point being, you might want to bring a spare electric motor with you, especially if you drive on the street...JMO.
I don't have the part number with me at work, but I know you can get those motors from Autozone for like 15-20 bucks (squirrel cage motor) as apposed to the 60+ dollars that Moroso charges.
if you get the part number I would love to have it! As for now I just carry the water pump pulley with me and old belt in case of an emergency. I have really no time on the car since I installed the little motor. Again waiting for my son to come to town before I go blow up the car! Lol what was the shortest time the motor lasted? Like do you think I'll make the 5 miles to the track about 10- 15 passes and the five miles back before the motor goes out?
