[WANTED] Alternator bracket
phish1270
phish1270
Iron Station, NC
I am looking for an alternator bracket like this one. This is the original one on a friend's '66 Barracuda 273. I can not find one like this anywhere. Any suggestions? Thanks for looking.
The later 60's one will work, unless you are doing a period correct resto.
They repo the late 60's ones.
We should have a few complete set's of them, off from mid-60s 273 motors.
Just PM, if you have not found them yet.
Have you tried sending a PM to member "cosgig" ? He's very knowledgeable on these Early A Cudas & may have what you need...Excellent to deal with too :thumbup:
I have the main bracket but need the swing arm now. It is longer than most & has a ridge along the bottom of it to add strength & rigidity. I will be looking for one at Carlisle but would love to track one down sooner if possible. Thanks guys.
I hope you don't mind if I jump on your thread. I also need these brackets. I see you've already found the main one, so if anyone has another, I'm in the market. Of course you have dibs on the first adjusting strap that comes available.
