Well you have two choices:
1 Throw parts and money at the problem, and THEN make some tests
2 Make some tests and determine the problem first
Might be a bad alternator, and might just be bad brushes
Might be a bad regulator
Might be a wiring problem
Might be a bad battery
Might be a combination of most/ all of the above
FIRST Charge the battery, find someone with a legitimate carbon pile load tester like this:
and have them load test the battery. If you can open the battery (old school with real caps) find a hydrometer and check specific gravity of the cells
load tester, 'xample:
hydrometer. Get one with a thermometer:
NEXT Some simple tests you can do
1 With engine running at fast idle to simulate low/ medium cruise, use an accurate meter to measure battery voltage right at the battery. When the engine/ battery/ regulator are warm, you should not have less than 13.5, not more than 14.5. 13.8---14.2 is optimum
2 If not, find the green and blue "push on" terminals on the alternator field terminals. Unhook the green, and install a clip lead from that alternator field terminal to ground. Again with the car running, watch the ammeter/ voltmeter and gently bring up the RPM. This SHOULD put the alternator in a "full field" IE "full output" condition, so if the wiring is OK and the alternator is OK, it should "bury" the ammeter at "C" at some RPM, and start raising the battery voltage. Don't allow it to go over 16V or so
3 If not, move your meter from the battery over to the alternator output stud and see what the voltage is there. If it's more than a volt or two higher at the alternator output than at the battery, you have a wiring/ connection problem in the bulkhead / wiring harness/ ammeter circuit
4 If there is no or low output, make SURE you have good solid battery voltage to the blue wire at the field terminal. Once again, you should still have the blue field lead connected, the green wire unhooked, and the terminal on the alternator which you unhooked should be grounded. So take your meter and stick it into the "blue" connector with key in "run" and make sure you have battery voltage
5 If the charging voltage is low in the tests above, above, your alternator is NOT putting out much. From here you can decide to dig in and try and repair it, or just find a replacement.
5 IF the above tests show that the alternator can put out good "full field," now it's time to decide if it's field circuit wiring or the regulator. Hook the green field wire back up so all wiring is "normalized." Turn the key to "run" with engine OFF. Check voltage at the blue field wire at the alternator. This should be within a few tenths of a volt the same as battery.
Now unhook the regulator connector. BOTH terminals (blue and green) of the regulator connector should be close to battery voltage
One last test you can make is this:
Again the green alternator field wire should be hooked back up. Unhook the BLUE field wire this time, and clip the unhooked alternator terminal to ground. Devise a way to jumper across the two terminals in the unhooked regulator connector. This operation will again full field the alternator, but using the regulator wiring. Run the engine, and if the alternator puts out "full" at RPM, the wiring is OK
If this last test shows OK, replace the regulator.
Also, if you do NOT get yourself a proper Chrysler service manual. If you have one for your 74? Consider contacting AbodyJoe so we can upload it here to the site
If you do NOT have a shop manual, you can download the 72 manual here for free. The wiring is DIFFERENT from your 74, but the main charging circuit is SIMILAR
The thread is here:
Some of the links in the top of the thread are broken, but have been fixed later on
http://www.forabodiesonly.com/mopar/showthread.php?t=132309&highlight=manual,+download
Direct link to the 72 manual
[ame]http://www.abodyjoe.com/pictures/Misc.%20car%20info/1972%20Plymouth%20Chassis%20Serv%20Man.pdf[/ame]
