This could be a few things
1.......Back in my wilder days, I had this happen (did this to) at least two Mopar alternators. Run the engine in darkness, raise the hood, and rev the engine up while watching the alternator. Now you must separate whether you are seeing slip ring sparking or "something else." If what you see is lots and lots of miniature sparks that seem to be out in the stator area, then what has happened is, the stator windings are loose, rubbing, and wearing the insulation off between turns
2.....Even if you have to run temporary wiring make some running tests. Monitor battery voltage and alternator output stud voltage and see if you can see voltage change at the time that the ammeter acts up. ONE VERY GOOD way to do this is to hook one probe to the alternator stud, and the other probe to the start relay stud. This gives you an "end to end" voltage drop from the alternator, through the bulkhead, through the ammeter, back out through the bulkhead, and to the battery.
3...Might be the ammeter itself or the connections to it, including the eyelet wire ends themselves. MORE LIKELY this is the connections in the bulkhead
4...IN RARE but has happened, the "welded splice" in the ammeter circuit may have failed. This is a factory welded splice a few inches from the ammeter in the black ammeter wire. You have to pull the cluster and untape the harness to inspect it. "Save it" for last, LOL
5...READ if you have not already, this excellent article
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
