Alternator Problems
Michael J.
Member
Waldo, Wisconsin
My 73 Valiant has a on off type problem that only happend in the colder weather. I will start it up and all is fine good voltage regulator fine. After driving for some timee never the same the regulator kicks off and I am running on battery only. 5 to 7 mile down the road the regulator alll of a sudden pops back on all is well again. This is a problem driving in the dark and winter here in Wisconsin at 5:30 AM. have checked all the wires and cleaned all the contacts and the grounds. Had the alternator checked and all shows fine,even put another one on and same issue?? Any help would be great.
Sounds like regulator is over heating This is why i had my local guy rewire my alt to a internal regulated one wire style. And i never looked back....
I am not sure if mine has an internal regulator or not? I know that the ignition is all electronis but not sure how to tell?
None of the original style alts like this are internally regulated.
Get a new regulator...OR..Get a square back and an electronic regulator, its just one more wire. (or a 1 wire alt, thats really a one wire mod!) The old points type regulators were just that, points opening and closing. Either the alt was full boogie or "off" back and forth but rapidly. Electronics vary the ground signal thus "regulating" the power output of the constantly energized (to varying degrees) alternator. Much safer too as a ground short (full on) on the old rounds could blow up a battery or melt a harness.
I could not disagree more. The 70/ later style regulators have been VERY reliable over the years. Only problem nowadays is getting good quality, non--Chineseo replacements.
There is no inherent reliability increase with these so called internal regulator conversions (actually they are externally mounted on the alternator) and since these are NOT a factory standard part, good luck getting one when you need it
Get a new regulator...OR..Get a square back and an electronic regulator, its just one more wire..
He SHOULD already have a square back AND a 73 already has an electronic regulator
But before you replace anything, CHECK a couple of things.
Pull the alternator off, and check the condition of the BRUSHES. They could be greasy, sticky, or just worn.
Pull the regulator and your ignition box off, and scrape clean under the mounting ears and around the firewall where they mate. Remount using star washers for grounding, AND as someone else on here suggested, "daisy chain" a ground wire of no12 from the block to the regulator and to the ignition box mount bolt
The reason Pishta suggested a "square back" is that they are better for low RPM output.
Square back / round back: Round back is an older design. ALL pre 70, grounded field (incorrectly called "single field") are "round back
Square back was 72? and later. IN 70, the round backs were "isolated field", as are all square back, incorrectly called "dual field.". To further muddy the waters, rebuilders many times drilled a hole in the rear of a round back 69/ earlier, and added a second, isolated brush holder
This thread shows the differences:
http://www.forabodiesonly.com/mopar/showthread.php?t=187013
If cleaning the grounds and inspecting or replacing the brushes does nothing, remove the green field wire at the alternator and install a clip lead from the exposed alternator field terminal to ground. This SHOULD cause full output. Start the engine, and gingerly raise the RPM. It should charge more as the RPM goes up. If you get the ammeter far to the right, ease off to prevent over--voltage. If this seems OK, you either have a bad regulator or a wiring problem in the field circuit
To check that out, go up to the regulator connector and inspect. Look for looseness or corrosion. Work the connector in/ out several times to scrub the terminals clean, and to feel for tightness.
Then devise a method to jumper across the two harness connector terminals. Go down to the alternator. Remove your clip lead, and reconnect the green lead. Now remove the blue field lead and install the clip lead from that alternator field terminal to ground. Once again, run the engine up, watch the ammeter, and it should show full output.
If so, the wiring is probably OK. At that point I'd replace the regulator.
Tony Thanks for all the information. I took the plug off the regulator on the firewall and replugged it into the regulator. Last 2 days no problem at all, can run full speed fan, wipers high beams, radio all together and voltage holds staedy all the time. I think the plug was just loose or not secure and temperature was a factor. thanks again for the help to you and all the other members.
