bbeep71
I want to make the Allpar.com mod to the alt. that runs a new bat wire(alt) to the starter relay batt terminal. This allows the alt to charge directly to the batt and takes some stress off the bulkhead connector. The car is a 66 Cuda. I don't know what the alt output is. It looks like a mopar stock roundback alt. My question is what type of fusing I should provide for that wire (8 awg) to the starter relay? Should I use a fusible link (what size link) or circuit breaker(what size). I have a 80 amp circuit breaker to use if that would do the job.
Thanks
Thanks
