Alternator wiring?
Valkman
NC
Can someone tell which of 2 ammeter wiring going to the to firewall goes to th alternator?
If you put it on the wrong side the ammeter will read backwards. Can't you look inside the car for wire color? How about MyMopar they have factory shop manuals and wiring diagrams.
Can’t answer that as the car is torn apart; however, as 67Dart273 said, if the ammeter reads backwards, swap the leads.
The left side closest to the alternator is alternator. The right side closest to the battery goes to the starter relay,
