73hcode
Ok trying to figure out something the bolt the alt. pivots on the one with the sleeves on it is there a bracket to go with it. Both la motors I have have air on them and a massive bracket and I am trying to find out if I need a bracket or just the bolt with the sleeves. The bracket I have bolts to the block in two places and is the one you tighten the bolt to with the adjustment for tension on the belt. The motor is a 77 360.
