[SOLD] Aluminum 22.5" 2-row radiator and electric fan
physixx
Edison, NJ
I have for sale a used Summit Racing aluminum radiator and Proform 14” electric fan. The radiator is a Summit Racing universal fit 2 row radiator #38028. The core measures 22.5” wide by 18” high. The overall length is 27 ¼” by 19 5/8” high with a 3” thickness. The upper hose connection is 1 ½” and the lower connection is 1 ¾”. It was used for 2 seasons in a drag car and never had any issues. The electric fan is a Proform #67014 and is a black 14” fan that spins 2500 rpm, has 10 blades and pushes or pulls 1,650 cfm.
It came from a 68 Dart GT bracket car.
https://www.summitracing.com/parts/sum-380428
https://www.summitracing.com/parts/pro-67014/overview/
I would like to get $100 for the radiator and $40 for the fan. $130 if sold as a package plus shipping.
Ken
Edison, NJ
Brackets from the top edge of the radiator to the radiator support of the car and then a brackets from the bottom edge to the radiator support. In the second picture, you can see two bolt holes at the top and then a single bolt hole at the bottom.
To answer the question on mounting. These are 1980s Ford brackets, slightly modified. Same piece is welded to the lower support to isolate the radiator. Cheap and easy.
