Aluminum Radiator available with a Shroud
lemondana
BlackDart
Southeast NE
Are there any aluminum radiators available with a shroud for the 22" for a 68 Dart smallblock. Or, will the stock 614 shroud fit on any rads available?
I am using a Champion 22" radiator and needed a shroud too. Bought an OE style one from Mancini Racing and had to modify it to fit. There is a thread on this forum on how to do that. Basically you need to cut the shroud in half and remove a little at a time until it fits perfectly. Cutting it in half makes it easy to remove too. You will use a piece of aluminum and screws to join the top and bottom halfs. Mount it to your radiator support by using plastic push pins.
Here is the link I used to modify mine:
Mounting a stock shroud on a Champion 22" radiator - 73 Duster
I have a wizard radiator and shroud, yes pricey but worth it imo . Car never overheats and the fit is good. Puts the fan centered in the shroud . If I have one complaint it’s that the mounting holes are a tad off .
