midlifecuda
- Joined
- Nov 13, 2008
- Messages
- 137
- Reaction score
- 48
Yes. I checked with a voltmeter and the full power is going to the radio. First thing this morning I replaced my starter relay which crapped out on me and had turned the Battery power off with a battery cut off switch I have installed. When I turned battery power on to crank the car I noticed smoke coming from the back of the gauge cluster which like I said was hanging out of the dash because I have been working on it. Either what looks to be like some sort of regulator or the noise suppressor touch the frame of the car . That’s the only thing that changed since last night when the radio workUnless you crossed a speaker wire to a power connection, you did not hurt the radio. Generally, you have the speaker wires, the orange dial lamp wire, the red main power, and the case ground. Do you actually have power to the radio? I mean, did you check?
