coro500net
- Joined
- Oct 15, 2008
- Messages
- 129
- Reaction score
- 14
I’m running a wire from alt to starter relay, just wondering if I should keep the original charging wire on the alt also?
Might as well bolt those ammeter wires together because the reading will no longer be meaningful.I’m using 8 awg from alt to solenoid with a maxi fuse in line. The engine, forward light and rear light harnesses are new, the dash harness is original and I cleaned all pins. The cluster is still out so should I still connect the amp meter wires together even though I ran the separate alt wire?
I did this mod and it made my electrical system more stable.The remaining "potential problem" is voltage drop in the ignition "run" line, which also feeds the VR "sense/ power" terminal, and therefore can cause OVER battery voltage due to voltage DROP
One way around that is to cut the ign1 "run" wire coming into the engine bay. Use the firewall side to trigger a relay, and feed the relay from the starter relay "big stud" through a fuse / breaker
Then connect the load contact to the other end of the cut wire.
