Does anyone have a thread for a how-to on converting the 67 Rallye dash ampmeter to a voltmeter? I saw on some threads of folks able to use the guts of a aftermarket voltmeter and mount them to the original gauge.
Sunpro CP8215 is still available at Ebay. You find that little round screen is barely attached. While captured in that housing this isn't a problem. Our larger triangular floating screen should have more substantial support in the long term scheme of things. Good luck with it.
The sunpro is now a bosch meter. They are exactly the same except for the faceplate as far as i can tell. I used one to convert the amp meter in my 72 demon.
