22dog22
Getting close to firing up my rebuilt 318, had front of car on jack stands, to fill cooling system to get the air to bleed out had a minor leak at the thermostsatic housing took off cleaned and used form a gasket, had car still front up in air on stands to put the header panel, bumper on car, noticed some antifreeze on floor on rt side rear of engine, checked it out antifreeze was leaking out of the rt rear most header tube where it meets the head, do you think I have a leaking intake manifold gasket have an aluminum intake ??
