Rat Patrol
Although my engine was built "on a budget" - using KB pistons, Eagle crank and cast iron heads - The assembly and machining was done with a view to the engine withstanding 500HP if I ever chose to make it work that hard.
The block was sonicced and magged - the crank was index ground, the assembly was internally balanced, and the block was square decked and trued.
The engine has never been taken past 6200 rpm and at the strip sees little more than 5800 as this is where it performed best.
Imagine my dismay last week when after a half throttle squirt - the engine develped an appalling vibration and rattle.
Today I found out why - the #7 / 8 rod journal has cracked - the overlapping journal then caught the windage tray and ripped part of it out, and the bearings were demolished.
None of the bearings removed show any signs of heat or detonation - and the converter (PTC) and balancer (Powerbond) are both SFI approved.
So folks - THIS IS A SIMPLE CASE OF COMPONENT FAILURE IN A SITUATION WHERE THE PART SHOULD HAVE COPED EASILY.
I would therefore encourage anyone looking at building ANY engine - to ignore the temptation to save a few $$ on the alleged "500 HP rating" of Eagle cast cranks - and simply by something better.
I will be.
I will be.
