[SOLD] Another Early A Combo
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
For the early A guys, here's another hard-to-find combination: a factory 65/66 front sway bar and a set of of lower control arms with the sway bar tabs out near the lower ball joints for this sway bar. I think the sway bar will also work with the 63/64 A's as long as you have the correct LCAs. I don't know whether this will fit the pre-63 A Bodies.
The LCAs will also work on 67-72; however the sway bar is not wide enough. If someone wants the LCAs for a 67-72, I will swap the early A sway bar for an aftermarket 67-72 sway bar that's been blasted and painted gloss black (3rd picture). Have got no other hardware to go with the later sway bar.
$250 for either plus the ride from 22657. It'll probably be oversize due to the size of the sway bar.
The control arms are from 64-66 or later?
I've heard that if the LCAs have a reinforcing washer welded to the hole in the sway bar bracket and came with rounded bumpers that they were early A 65/66 LCAs. These have the reinforcing washer and came with the rounded bumpers (not shown in the pictures for what it's worth.
