Another ? for Brett
onehellofadart
Moonachie, N.J.
Brett, do you run a MSD ignition? The tech @ Summit said the tech at MSD says the light won't work with a MSD ignition. Said no advance timing light would work with MSD correctly. ????????????
If he is refering to multiple spark boxes then my crane is the same thing and it works fine. ZEATER also has MSD with the same light and it works fine. I have not compared it to a standard light but then I would have to rely on accurate advance marks etc etc. Who really knows. If I click the light down 5 degrees it moves 5 degrees on the timing chain cover marks. Besides, find me a light or someone that can set the timing and by the time you tighten the dist etc you are probably off a degree anyway. As long as you stay with one light and tune from there you will alway's be consistant. If you had a $50,000 race motor then I would worry about a degree here or there but otherwise just use it for a tool to go up one degree or down one degree. It is perfect for that.
