Cuda68Scott
That's a nice welder! I have been looking at some Millers lately, a few grades below that one. Can I adopt your son?
Merry Christmas, 67....
I better hide that comment of yours from him. If he realizes he could replace me I'll never get a plasma cutter.
Just tell him I am that black sheep uncle the family never talks about...
I here you on the weather. Those that manage to get something done either are tough sons a bitches or they have a nice dry heated garage.. My garage is all concrete and no heat.
BRRRRRRRRR.
needsaresto, I don't know what the temperature is way up there in the land of moose but it has to be worse than it is down here. I've always imagined Canada to be within a stone's throw of polar bears.
One thing's for sure. If I ever build a new shop I'm going to insulate the crap out of it.
In floor heat is awesome!!!!!!!!!!!!!!!!!!!! Ask me how I know.
Hey Cuda........You have ary Wheel trim Molding for 67-69 cudas? Prefer good ones. thanks, SP.
You would never go back to a forced air type ever again.rayer:I've always wondered about the floor heating systems. I've been skeptical.
What I've heard is that they are cheap to run but I've wondered whether or not they will really make a place comfortable. I can understand that the floor would be warmer to work on.
You can keep the thermostat about 65 and when you are working, It's t-shirt weather.
Does the heat really transfer up through the shop?
Yes
How warm can you get it to be?
warm as you want
Are they really cheaper to run?
yes
How long does it take them to warm a shop up?
we start ours in the fall and run all winter. You don't want to run one intermittently, takes a long time to warm that hunk of concrete up. Then the boiler runs continuously until the building is up to set temp. Once the slab is warmed up, the boiler only runs to keep temp set.
Do they run continuously?
not after initial startup.
Do you run a second form of heating system with it?
I have a backup lp boiler, but I haven't used it since hooking up wood boiler.
I realize that there are sites out there that have information about these heating systems but I figure that they are likely to make things sound better than what they are. I've never talked with anyone that actually uses one.
I sure wish I had a lift. These pictures may make the car look like it's in a precarious position, but it's actually supported with multiple jacks and jack stands. The rectangular tube frame is inboard so the car seems to be floating without much support.
With less than two foot of clearance from the floor it's not a lot of fun laying on my back as I'm cleaning/painting the undercarriage. I've been brushing the paint on so I'm having to contend with paint dripping back down on the floor and myself. As I scoot around underneath my coveralls are absorbing some of the paint from the concrete and cardboard.
As much fun as I may have had buffing aluminum, this job has to be on par with it. I'll put it on my list of things I need to find an illegal immigrant to do for me.
