AdamR
Big Member
Todays project was to paint the hood. I did the underside this morning which was easy. after it dried for 6hrs I flipped it to do the top. It came out pretty well.
I put 2 medium wet coats on it. It look like it has some striping in it. Is this gun set up related or just my spraying technique ? Does it need another coat ?
Also how may coats should I spray if I plan on wet sanding a panel ? Im afraid my 2 meduim wet coats are to thin and I'll burn threw either wet sanding or buffing it out.
