Hi Folks
Not sure if this is normal.............
I ran my TQ on a run stand and it performed great. When I removed it from the engine the following day, I noticed gasoline on both sides of the plenum floor of the intake (old school performer). I am not sure if it was there from running the previous day, or it leaked there?????
At any rate, I tore the carb down again and found no anomalies. I verified that the brass floats were dry, and confirmed the level was set at 1 inch with gasket on the top plate.
I filled the bowls with fuel and let it sit for 2 hours and checked the fuel well epoxy for dampness and found nothing.......And no drips on the work bench.
Do these things ever siphon through the main discharge nozzles or the accelerator pump circuit???
Am I chasing my tail, or is there something I am missing?
Thanks FABO
Thanks FABO
