metallidart
member me?
Kids are watching Spongebob, so I am stuck sitting and thinking about my engine. I figured I would bounce some ideas off of you guys.
The engine : 1970 340 block, bored/plate honed, decked for zero deck, line honed, main studs/girdle, JE flattops, Eagle H-beams, Scat 4 " forged crank, balanced, lifter bores bushed, etc. Compression will be about 10.75 or so,comp custom grind solid 275/288 adv, 250/254@. 050, 104ls,. 584/. 568 lift with 1.6 rockers. I bought it barely used with just a little dyno time. I talked to a guy from comp, and he said he couldn't recommend a better cam, especially for lowering my cylinder pressure to help it run on pump gas.
Heads will be a set of 1973 587 heads. I will be doing the port work, but I will have them cut for 2.02/1. 625 valves. I have done a few sets of heads, and always had good results, so I amgoing to try to go all out on these. Also got some good head-porting threads on here to refer to!
Intake is an LD340 that I will port match.
Now my questions.
-would I be better off with 2.05 valves?
-should I just use 1.5 rockers? I will be buying the Hughes rollers.
-what size carb would you guys recommend?
And lastly, what kind of numbers do you guys think?
Car is a 1973 Dart Sport 340, 904 with a 3300 stall (but that was with my mild 360, I am sure it will be higher now), and 3.23 gears, for now.
Any quarter mile guesses?
Now my questions.
