swifterthanyou
Hi there.
I am cleaning out the garages of all my extra parts so please check out my other listings as well.
***10/27/17 I just posted a set of 1973-76 lower control arms with new bushings and correct sway bar tabs under a different listing that would work awesome this this front setup***
I am selling a new set of front and rear Addco (anti) sway bars with all mounting hardware and instructions. Never installed? New with urethane bushings. These will fit 1967-1976 A-Bodies with either the supplied mounting hardware of if you have a set of 1973-1976 lower control arms with the mounting tabs (even better). They will mount to all K-frames with our without the original brackets.
Front bar is 1 1/8" and rear is the 7/8" (thicker bar).
Check out Jegs pricing for these bars, they list front for $188 and rear for $159, I am asking $275 plus the ride (UPS Ground from 20711).
