Maybe it depends where you're from, but here, as long as the tag is from the same province and not already registered, all we need to do is show them the plates, and they will issue a sticker for them.
Granted the same number is not being used, due to being replaced for damage.
Call your local DMV (better then waiting in line), they will let you know what is acceptable for your state.
In mIchigan, the plate needs to be the same year as the car, unless there was no plate for that year, then you can use the plate from the year prior to the "tag" year. Geof
