A abodyhotrod Well-Known Member Joined Sep 17, 2007 Messages 292 Reaction score 2 Nov 10, 2009 #1 running a 27x10.5 tire now. how much taller of a tire will fit and what mods might have to be done. i can go 3in. wider.
Burntorange70 Well-Known Member Joined Feb 18, 2008 Messages 12,873 Reaction score 147 Location Aguanga, CA. Nov 11, 2009 #2 From what I here 28"s are the limit. Here is a good wright up on how to widen the wheel wells. http://www.bigblockdart.com/techpages/wopen.shtml Or you could move the axle back. That will give you a little more room for a taller tire but will all so make your weight distribution worse.
doug 371 Well-Known Member Joined May 29, 2004 Messages 2,897 Reaction score 1,375 Location Regina, SK CANADA Nov 11, 2009 #3 open the front of the wheel opening all the way to the outer wheel house front...
A abodyhotrod Well-Known Member Joined Sep 17, 2007 Messages 292 Reaction score 2 Nov 11, 2009 #4 thanks burnt thats what i need to do. i wonder what size tire that was on that dart. i was thinking of going to at least a 30in tire.
Burntorange70 Well-Known Member Joined Feb 18, 2008 Messages 12,873 Reaction score 147 Location Aguanga, CA. Nov 12, 2009 #5 A 30' will fit but if you go much taller more cutting and stretching of the fender will be needed.
AdamR Big Member Joined Dec 31, 1969 Messages 17,343 Reaction score 560 Location Bethel, CT Nov 12, 2009 #6 Move the rear back
S Stormy69 Dusted Joined Sep 5, 2009 Messages 176 Reaction score 4 Location Mtn Home AFB, Idaho Nov 13, 2009 #7 i have a 28 x 10.5 slicks on the stock wheel opening and 1/2 inch clearance at the front of the wheelwell
