Any help with what these parts go to?
halfafish
Damn those rabbits, and their holes!
SW Washington
Howdy all. I bought a parts lot and have a few things I'm not able to find a positive ID. Any help would be appreciated. I'm going to sell this stuff but I want to correctly identify it in the ad. Most of this is slant related and likely from a 64 or 65 Dart.
There are a pair of chrome trim spears. I think they're the sides of the U-shaped trim on the hood or a 64-65 Dart. They are about 32" long. The numbers inside the fat ends are 2417704 and 2417705.
A pair of engine mounts, probably poly, they're too stiff for rubber. Any clue what they fit?
OK, so I'm smart enough to read the box for what it is, but I've never seen one before. How do they work? There are no instructions.
Last one for tonight. A sway bar, marked "A body" but no model or year. Any clues? The bar is a hair over an inch across and about 46" wide.
sway bar isn't stock-- the mount tabs are for shock mounting instead of to the factory tabs. likely 67~72 judging by that width.
factory 73~76 bar measures 37" eye to eye centers.
73~76 setup measures 43~44(ish)" shock to shock
This is an easy one:
Those can be used to lift or lower a vehicle with leaf springs by placing the aluminum block/spacer between the spring and the axle housing. Because they move the axle further away from the spring, you need the longer U-Bolts.
